dhiraj_santhanam
When I connect my phone to my lap or PC using the provided wire it's not getting connected instead it's just charging..... I can't open my phone in my lap neither transfer files need help please......
When I connect my phone to my lap or PC using the provided wire it's not getting connected instead it's just charging..... I can't open my phone in my lap neither transfer files need help please......![]()
I assume you are not talking about ADB drivers (see the link in the answer above this one for that) but rather using an MTP connection to view your internal memory from Windows Explorer and transfer files.
The same drivers should work for the MTP connection too.
Actually nothing happens no popups it just charges
How to go to device manager
Hey I've had this problem too now if I remember correctly got to setting>storage and in the top right corner there should be a menu/options button or 3 vertical dots click on those and there you have it should work if not it's the cable/USB port
This :thumbup:Hey I've had this problem too now if I remember correctly got to setting>storage and in the top right corner there should be a menu/options button or 3 vertical dots click on those and there you have it should work if not it's the cable/USB port
Wow it's working I tried the storage media 3dots m manual selection of mtp
But what happened to automatic detection
Disabled by default you have to manually set it and your welcome
