Hi Woohooguy.. I have a Xiaomi Mi3. same issue. phone doesn't charge while connected to OTG device. the split OTG cable powers the external device like HDD and Pendrives, but not the phone. You have mentioned that some rooting operation can enable this. could you please let me know what exactly needs to be done here.You will find that the nexus does not charge when in USB host mode unless you are running a custom ROM or kernel that specifically address it. In theory it will power the USB device and not the nexus.
I have had some issues with various powered OTG cables in the past, some would crash and hard reset my N7 when power was connected, some would cause the n7 to not reconize any USB device until power was removed from the connector but once mounted plugging in power would safely power the USB device only.
I have a generic no name powered OTG cable I only use when mounting my WesternDigital Passport drive as it has no external power connector, it draws all its power from the USB host and the powered cable greatly extends the runtime of the tablet as it powers the drive only.
For regular USB devices like thumb drives I use a generic otg cable without a power connector for simplicity.
