Anyone know if it is possible to fix or replace the usb port? Mine is loose or something and now I have to tilt the charging cord upwards to get it to charge correctly
I've done this before...but I can't recommend doing it...
Sometimes the pins on the inside become loose and bend...Either take the phone apart and see if you can bend the pins down...or you'll have to buy a part and re-solder it on...
Alternatively, you can try to contact ZTE, so you don't void the warranty.
agreed about changing the cord vs the phone, I have some old motorola chargers I use and they are loose sometimes and I had to move the phone to get it to charge, I switched cords and it works fine now.
Its not my cord... I have 3 and none work.... I was praying that it was the cords but nope... this has happened to my previous phones... and soldering is definately not in my skillset
