Root usb question (alternate usb)
rleal2010
I want flash my phone back to stock tonight, can i use a blackberry usb cable to do it or do i need the one that came with the behold?
You should...USB is universal (hence the U). If by some reverse miracle the chord is nonstandard, you would not be able to get adb to connect. And you would damage anything by trying (the 5v and ground have to be in the right spot).
