Hello
I have a problem with my usb-connection to use with some apps. When I plug in a usb stick with an otg-cable my device recognizes it on my tablet (nvidia shield) so i can browse in a pre installed app. Also in the app ES File explorer it shows the usb device.
I also would like to use in it a folder music player like music folder player and others. The problem is I can only browse the files on the internal memory of my tablet and can't see the usb folder.
Anyone has a solution for this, much appriciated.
Kind regards,
J6
Kind regards,
J6
