Root USB Storage write protected - NS 2.3.6
Hi , I am trying to root my device and I am unable to copy the Superuser.zip over because of write protected usb storage.
Steps I have done.
unlocked bootloader via fastboot
flashed clockwork mod (.img from Wiki)
in recovery , mounted usb storage from within Mounts and Storage.
I then attempted to copy Superuser.zip thru windows explorer and it says write protected.
If I reboot the device and go to normal mode, and try to mount USB storage it does the same thing.
I did install the ADB drivers from SDK and windows detects the device as such when I go into recovery.
Any ideas?
Thank you
edit: not sure where it broke, but my guess is the drivers did not install or something because I tried it on another computer and it worked. Only difference is , I copied superuser.zip over to the device, then did the clockwork mod , then recovery , mount , install from zip. Before I did clockwork mod, recovery , usb mount , tried to copy over the .zip .. and this is where it said write protected.
This thread can be closed.
wow dude .... why all the headache ? flash recovery .img and then flash a custom ROM with SU ,like CM 7 ...you are done !
