use 7Notes with mazec inside of Evernote?
eslate999
I want to use the handwriting recognition of the 7notes with mazec when I create, edit notes in Evernote. I use Swiftkey otherwise, and only want to use the HW recognition app in Evernote (right now). As a Tasker newbie, I only can open 7notes after I open Evernote and it gets "in the way", where Evernote has a "panel" screen to navigate before where I might create, edit notes.
A search for even Evernote or 7notes with mazec came up blank for this Tasker forum, any suggestions would be awesome.
Thanks!
I'm not totally sure what you're asking here. Can you do this manually? Tasker can't really do anything extra for your phone, it can just automate things for you.
You could open Evernote whenever you're in the handwriting app, and %CLIP is set (the clipboard)... A quick search reveals that the app you're talking about integrates with Evernote already
I don't want to have to manually change the input to 7notes every time because I like using Swiftkey in every other app. Also, the 7notes notes interface or note taking template is crude and I want to work within evernote.
