use flash player
  • Start date Start date
A
Android Question
Guest
Acer a501, need flash player, or similar, to play games and view some clips
Searching with your browser, type in "Archived Flash Player Versions" and it will take you to Adobe's archive. Just look up which version you need, download, and install it. The last supported build was for Android 4.0. I do know that some of those versions will work for newer Android builds.
Just do a little research and find out which one will work for your device.
