I've bought a used S5 in average condition so I'd expect a few issues.
Firstly the flap for the charging port is missing so I've ordered a new one which should stop the waterproof warning message from popping up regularly. I also seem to get a warning message about the rear cover now and then too, it does seem to fit well with no gaps or loose connections but would the message indicate that's not the case?
Also should there be some sort of plug for the earphone socket to ensure it's fully (or as much as the S5 can be) waterproof?
Finally next to the charging port is another socket of some kind, what's that for?
TIA
TIA
