Greetings ! Newby new to forums here.
So I tried to charge my Huawei Premia 4g (MetroPCS) phone using a Rocketfish Mobile Phone Charger (Model# RF-MIC90) with the following specs:
Input: AC 100-240V 50/60Hz 0.2A
Output: 5V_ _ _0.6A
After plugging the Rocketfish charger into the wall outlet and then plugging the other end of the charger into my Premia it appeared as though the phone began charging (battery charging icon appeared) but the phone screen immediately became frozen. I tried to power down but nothing... the phone appeared to be totally frozen. I unplugged the charger from the phone and the screen blacked out. It appeared as if the phone lost all power (without the normal power-off process). It would not turn on normally so I removed the battery for a few minutes, re-inserted the battery, attempted to power up... it will not power up. No lights or any indication of power.
*** I tried to hard-reset the phone by depressing both volume buttons and the power button all at the same time... still nothing... no power... no reaction from phone at all.***
I fear I may have zapped my phone into a coma/death by using the wrong charger.
The phone battery was less than 50% charged when I plugged the Rocketfish charger into the phone (probably more like 25% charged).
The Huawei charger that came with the phone from Metro PCS has the same specs as the Rocketfish Charger except that the Huawei charger's Output is: 5V_ _ _1.0A (the Rocketfish charger's Output is: 5V_ _ _0.6A).
On the phone I do see a red light flash quickly on and off, one time, only when the phone is being plugged into a usb port on my Toshiba laptop without the phone battery being inserted. This quick one-time red light flash does not occur when the phone battery is installed and then the phone is plugged into the usb port on the laptop. This situation is the only occurrence where any light flashes on the phone. Otherwise, no other light (of any color) flashes on the phone at all.
Anyone have any experience/suggestions as to what may have happened? Or any other suggestions as to how to reboot this phone somehow? Thanks!
Output: 5V_ _ _0.6A
