Seems like I got NO actual feedback from the useless reviews of the droid 2 so far so I'm listing the differences that I have noticed on mine so far.
1: it loads up all your old apps and updates them automatically upon activation, all my droid replacement refurbs didn't do this
2: its faster (can't tell how much until I've used it for a few weeks) but transitions through screens are smoother
3: it comes with motoblur supposedly, I don't even know what this is, so I can't tell any difference, thus anyone who wants a droid 2 but to have it operate like a droid 1...mine does...so uhhh I don't get it.
4: the graphics are different, icons are different, I like both the droid 1 on 2.2 and the droid 2, they are similar but the colors are often reversed in a lot of menus
5: ergonomically it feels better, camera button and volume button are much better feeling.
6: battery door cover looks almost identical but the foam is thicker and it is on their tighter than any of my 4 droid 1's
7: keyboard is much more tactile with the raised buttons and I like the arrows much better than the dpad, however I'll use the pre-installed swype for most my typing since that's what I'm used to.
8: calendar still doesn't scroll in month mode LAME only scrolls in week mode
9: camera mode is faster on droid 2..I think....I initially started it and droid 1 took 10 seconds to load, but after a battery pull they are closer in speed, so hard to say if there's an actual difference.
10: the unlock swipe takes longer on the droid 2...dunno why
11: on droid 1...gmail would always get confused on conversations that were of the same subject line for example if the subject was blank, it would combine emails from different senders....and it wouldn't show the correct email unless you got in the emial out and back in, droid 2 doesn't have this problem, it just shows EVERY email in the list, and you can scroll from oldest to newest...big improvement
12: start up time from power on is about 2 seconds faster on droid 2...not really a marked difference
13: all the icons are different...I actually perfer all the icons on the droid 1 versus the droid 2...but i'm not that 14: forgot to mention they changed the order and icon for the menu / back / home / search buttons on the screen...this is just annoying..why did you have to change the order...lol..I'm used to my back being all the way on the left, now it's 2nd from the right.
15: the alarm is much improved, it used to switch between portrait and landscape as you try to snooze thus cancelling the alarm, it now functions where the entire screen is the snooze and in order to cancel you have to slide to unlock...so to speak
15: Gallery is improved, it allows scrolling up and down with the slider that's found in contacts and it references the dates the pics were taken so you know how old of pics you're searching through
16: Camera has integrated gps function to show where photo was taken
17: separate camcorder app
18: power, volume, and camera buttons feel much better, fit and finish is much tighter
19: usb fits much tighter then before
20: speed while loading memory heavy application is greatly improved such as raging thunder 2, the load time is about 5 seconds faster.
21: has DNLA so you can share photos / audio / video with tv's or computers of the same DNLA technology
22: the market is different: shows comments in their own window AND allows for automatic updating, you can select this per app, I don't remember this being on my 2.2 droid 1???
