Useless calendar
TMyers
I have a Samsung Galaxy S and the calendar event tone sucks. I need to find something new that lets me use my ringtones. I really need help with this please.
Hello TMyers. There are countless calendar apps to be had. Each have their perks. You might try asking your question here: Android Applications - Android Forums That is a spot on AF where we discuss apps. I've talked calendars there myself. You should find something informative. While you are here, you might want to check into the sub forum for your Galaxy S. You will find it here:
Samsung Galaxy S - Android Forums
Good luck and enjoy the forums.
