Read through the methods several times and make sure you understand it. Lots of folks use these root kits that does everything for them. I have done it manually on all of my devices I've ever owned and never had a problem. The knowledge gained in this process is invaluable if you run into problems as well. It's basically just a handful of commands entered in the terminal with your tablet connected via usb.
Edit: as with all Macs, you do not need the drivers the rooth thread talks about.
