Using Android with apple CarPlay
Stu_C
Hi all
I have recently just bought a 2019 BMW new car and it only supports Apple CarPlay, is there a way I can use my android instead without having to pay a 3rd party company to basically take my whole dash apart to fit a new system?
  • Like
Reactions: Rob
Sorry, that's never going to happen due to Apple. Yank that out and get an Android compatible unit
Don't really want to rip it out when the price is not cheap might have to swap to Apple, just didn't know I'd there was an module or anything
  • Like
Reactions: Rob
Hi all
If your 2019 BMW only supports Apple CarPlay but you'd like to use Android, several options can help without extensive dash modifications.
First, check for manufacturer-provided software updates for Android Auto compatibility. If none are available, consider wireless dongles that can add Android Auto support, plugging into your car's USB port.
Some apps can mirror your Android phone's screen on your car display.
However, for a more comprehensive solution, you might explore aftermarket head units that support both CarPlay and Android Auto, but this involves professional installation. Research compatibility and choose an option that best suits your needs.
  • Like
Reactions: Rob
