Using DOS script, how transfer files to S6?
vpelton
Member
First off, what I CAN do is plug my S6 into my PC via USB & use Windows Explorer to copy files to the S6. From the PC I can open these files on the S6. When unplugged, I can open these files on the S6.
What I CANNOT do is copy the files with a DOS script. I did this with my old Android phone, but not with the S6. I think the issue is, I don't know what path to use for the S6 in the script.
In the old days, when I plugged in my phone, it was shown as a drive letter. With the S6, it shows as "Computer\SAMSUNG-SM-G920V\Phone\". But when I use that in my script, it doesn't know it's the phone & just creates a dir of that name on the PC & copies the files to that new dir on the PC.
Here's what my DOS script has that works on my old Android phone:
set DEST=j:
cd C:\Users\user_name\Documents\vehicle
xcopy car_battery.doc %DEST%\vehicle\ /Y /D
Why do I want to do this? I have a lot of files & they change all the time on my PC. Once a week I run the script to get the latest on my phone. For various reasons, programs like Dropbox do not work in this case.
So, the question is, without a drive letter, how do I specify the phone in my DOS script?
You absolutely cannot do that with a simple wired connection.
http://superuser.com/questions/369959/how-do-i-access-mtp-devices-on-the-command-line-in-windows
http://d0bon.blogspot.com/2014/07/map-drive-letter-to-android-mtp.html
You can do it wirelessly, no problem.
With working adb drivers, you may be able to do it via USB and some extra configuring as explained in the app description below.
Wireless is going to be far easier.
Check out "WebDAV Server"
https://play.google.com/store/apps/details?id=com.theolivetree.webdavserver
OMG! This is awesome. I've been struggling with this for a long time & now it all works. Simply amazing. I really appreciate your help.
For those reading along, here are my notes (using Vista on my PC).
on phone:
run WebDAV Server app
on PC:
double click on Computer icon on Desktop
click on Map network drive (drive letter automatically appears, e.g., z: )
Folder; use value showing on phone but using backslashes, e.g.,
\\192.168.0.104:8080
Reconnect at login (check)
can now use z: in script
Yeah!
