Apps Using external library (no .jar, folder with .java instead) in Android Studio
Hello, I just started a default project in Android Studio, compiled, and it worked fine. Now, I downloaded a library, that is, in fact, a folder with 3 .java files: one Main.java for testing and 2 Classes for usage on my app. I want to know two things:
How do I compile these files to use in my project? I simply put the folder inside app, so this is my structure:
src/main/java/com.example.myname.myapp/MainActivity.java
src/MyClassFolder/Main.java
src/MyClassFolder/Class1.java
src/MyClassFolder/Class2.java
src/MyClassFolder/AnotherLibrary.jar
So, what I wanted to do is this: I want to compile these files as they are in this folder, without having to move them to MyclassFolder/src/main/java.
I've found these instructions at the internet:
At /app/settings.gradle, i nclude this line:
include ':MyClassFolder'
edit /app/build.gradle and add, in dependencies, the line:
compile project(':MyClassFolder')
I did it, but this happens:
I seached and I think that it's asking for a default build.gradle file inside MyClassFolder. How may I create this folder? How can I tell gradle to compile these files in this folder, and how do I insert parameters to javac?
Also, what is /app/build.gradle for?
I also tried to move files to /src/main/java to see if it would work but it didn't also. I'm very confused :c
