Help Using External Mic with Note 10+
The_Chief
Accept no imitations!
  • Nov 17, 2009
    15,580
    17,417
    Manchester, Tennessee
    I have an event coming up that I will be recording with the Note 10+ video camera. It's outside... so I purchased an external microphone to put on the podium, running a cable to the Note 10+ on a tripod.
    After trying just the mic and cable, I got nothing. I did a YouTube search and learned that I needed an adapter with a built-in DAC like this one.
    NO SOUND!
    Does anyone here know what I'm doing wrong? Thank you!
    SOLVED!
    After watching several YouTube videos, I learned that the TRS to TRRS adapter cable is VERY important... without it in the right place, audio recording ain't gonna happen.
    The cable's 3.5mm plugs are different: one end has two black lines around it; the other has three. It is CRUCIAL that this cable plugs directly into the DAC adapter, which plugs directly into the phone.
    I had an extender cable to allow for more distance from the microphone to the phone... it's a TRS cable, with only two black lines on the 3.5mm plug. I had the adapter cable plugged into the microphone, and then to the extender cable - which was then plugged into the DAC adapter. WRONG! Connecting that 3-line TRRS plug into a 2-line TRC cable broke the whole thing!
    Once I realized this, I connected the extender cable to the microphone... then the adapter... then the DAC... and the phone. Works brilliantly! Here's the video that gave me the tech geek epiphany: Awesome information video
    Upvote 0
    A wireless mic would be great... but that particular mic wouldn't serve our purposes. The description specifically states, in bold letters:
    This item is for recording only, NOT for real-time project such as karaoke or live presentation.
    Since this is for video recording our live ceremony, it won't work. Thanks for the input, though!
    Upvote 0
    BEST TECH IN 2023
    Smartphones
