I am making a server-client application in which a client can download files from a server. I am building the client side as an android application.
I am creating a Handler class as follows which is suppose to call the list()
function which displays a dialog box with list of the result returned by the server;
initialize() is used to initialize and the class also defines an onClick() action which runs the background thread which will send a message (result obtained from the server to display as a dialog list)
The problem is that I cannot call the function list() from within the handleMessage() method defined above . The application collapses . How do I update the screen whose action depends on a background thread?
Also I cannot call another activity from within the handleMessage() method.
Code:
Handler handler = new Handler(){
public void handleMessage(Message msg)
String result [] = (String[])msg.obj;
System.out.println("Calling list function");
list(result);
public void list(String a[])
final String items[] =a;
AlertDialog.Builder builder = new AlertDialog.Builder(Search.this);
//Set it title
builder.setTitle("Download");
//Set the list items and assign with the click listener
builder.setItems(items, new DialogInterface.OnClickListener() {
// Click listener
public void onClick(DialogInterface dialog, int item) {
Toast.makeText(getApplicationContext(), items[item], Toast.LENGTH_SHORT).show();
AlertDialog alert = builder.create();
//display dialog box
alert.show();
//sk.setTexat(d.readUTF());
Code:
// TODO Auto-generated method stub
setContentView(R.layout.opening);
try {
initialize();
} catch (IOException e) {
// TODO Auto-generated catch block
e.printStackTrace();
public void initialize() throws IOException
music = (RadioButton)findViewById(R.id.music);
videos = (RadioButton)findViewById(R.id.video);
books = (RadioButton)findViewById(R.id.books);
d = (EditText)findViewById(R.id.Search);
k = (TextView)findViewById(R.id.connection);
b = (Button)findViewById(R.id.Go);
sock = staticsocket.socket;
System.out.println(sock.getRemoteSocketAddress());
k.setText(sock.getRemoteSocketAddress().toString());
b.setOnClickListener(this);
dout = new DataOutputStream(sock.getOutputStream());
filetype = "Music";
@Override
public void onClick(View v) {
filename = d.getText().toString();
//String name[] = {"hello","world"};
String name[] = new String[10];
try {
dout.writeUTF(filetype);
dout.writeUTF(filename);
catch(Exception e)
{e.printStackTrace();}
Thread o= new Thread(new Runnable()
String filepath = null;
public void run()
String resulta[];
resulta = new String[10];
try{
DataInputStream din = new DataInputStream(staticsocket.socket.getInputStream());
// String resulta[]= new String[10];
String result;
int i = 0;
while((result=din.readUTF()).equals("finished")==false)
resulta[i] = result;
catch(Exception e)
Message msg = handler.obtainMessage();
msg.obj = resulta;
handler.sendMessage(msg);
o.start();
System.out.println("thread started");
