Using Internal Memory instead of SD Card
nourgomaa
Hi There! :) ,,
I have Nokia N900 Android V3.2
I could repartition the SD card and install android vostok perfectly with no problems,
Android works perfectly with no problems... Fast, stylish and faster -In my opinion- than Maemo.
But i have only one problem.... :rolleyes:
Android uses the internal EMMC as external memory (SD Card), and i have many problems with my 32GB Internal memory
The SD Card became "1GB For android system files, 6-7GB for normal use)
Do u think that's a way to use the excess of rest storage on SD Card instead of the internal EMMC on android? :)
I hope u help me in that... Because i want to use Android on my N900 :)
Hope u understand what i mean.. (32GB internal memory "Android use it as SD Card", and 8GB SD card"android use 1GB as internal memory" And i want to use the rest 7GB as my SD card instead of EMMC)
I tried to mount EMMC partitions on SD card.. I lost everything :D!!
Sorry for lengthy...And thanks in advance :)
Regards...
