safe answer - i wouldn't use anything petroleum, alcohol or ammonia based on what i believe is a plasticized display - iirc, samsung indicated the capacitive sensors were laminated under a plastic film
besides, what do you expect to get on there that a mild soapy water solution won't clean?
if you've got a screen protector on it, if a water or mild soapy water solution won't clean it, replace the protector
