Help Using my phone as a bridge/repeater?
cdhoyt86
Alright. I've spent two days searching for information I'm asking for help with now. Here we go:
I recently found out that my 4 GB data plan has been almost entirely destroyed by me carelessly using crap tons of it to watch videos and whatnot. At work, I have a bar that has an open WiFi across the street, but my laptop for some reason doesn't connect to it as well as my phone does.
If I (1)completely shut off my mobile data for my S3, (2)join the bar's open WiFi with my S3, (3)connect my laptop and my S3 together with a USB cable, and then (4)tether my laptop to my S3, will I be using data? In my head, I wouldn't be.
However, I apparently used a metric crapton of data when I did all of the aforementioned things with the exception of turning of my mobile data. I don't know if this is true, but I suspect that I was using both the open WiFi and the data connection. My phone says I have only used like 1.8 GB out of 4.0 GB, but Verizon has bursted my bubble and sent me a few notifications saying I've used 3 GB.
Thanks for the help guys.
When I tether via USB (Galaxy S3), my S3 utilizes wifi if its connected.
you can check this by going into settings and monitoring data usage.
Also if you turn Data completely off you will not receive any MMS and a few other things that only work on network Data.
