Musky
Android Expert
It depends on what IP addresses your work router will recognize. Hopefully the address you assigned your laptop won't conflict with another device on your work network. The ranges are pretty common so you may be fine. If not, you will need to switch back to "Obtain the settings automatically". Then when you get home, you would need to enter the set of three numbers again. But that is the price you may have to pay for using FoldeSync at home.
My router, which is supplied by my ISP, lets me set an IP address for my laptop as "fixed" so the router saves that IP address for my Laptop using my laptops adapter's MAC address.
I don't think your Linksys has this feature, but maybe you can find a router that does.
