D
Deleted User
Guest
Welcome to GamerROM Orbis® the all new OS that gives you max performance, more internal storage, more control. We baked up some cool features and hope you enjoy them
Features:
• No Google Play Services Ever (OS is designed to prevent any install of GMS and saves battery and performance)
• Quickboot is back set your phone to standby mode without fully shutting your phone off
• Adaway Included prevent ads from apps including browser from popping up and allowing you to enjoy a game or app filled with spammy ads
• 1.18GB of internal Storage is yours to use
• Customizable OS Vis CM Theme Engine
• Old fashion google login framework (be aware logging in will crash but no worries this is normal and will add your account no matter what)
• Gmail Is included (Not Updatable)
• Latest Webview and Play Store installed and much more.
• Camera patch has not been added to OS so green video recording may still be present
• Location in some apps may not work correctly you'll need to set your location manually if app allows you to, however some older apps usally works with our location servers
Download: http://gamerromos.weebly.com/samsung-galaxy-exhibit.html
Notice: this version uses our online OS interface if you connect to the internet basically it cross sync with GamerROM Online to ensure best online experience but will still function normally offline.
