Vanilla ICS multi-task on One X?
zmbchclt
Now, apologies if this is somewhere already, but I honestly can't find anything, so point me in the right direction if so.
Ok, so on the likes of JDroids AOSP ROM etc, is there anyway we can get the Vanilla ICS style multi-tasking instead of the Sense?
It's much nicer, can see open apps more clearly etc as you'll know.
Any help is appreciated.
Thanks,
Richard.
Thanks,
Richard.
Not sure if this is what you are asking but can you not use a different launcher and not Sense to do this?
Something like Nova Launcher?
Different launchers do not change the multitasking menu. That is something that is baked into the specific ROM unfortunately.
Unless you flash a Vanilla ICS ROM then you can't change it.
No idea why HTC changed the memory values, if you're rooted you can flash a mod to improve the memory management.
I'm pretty sure zmbchclt is talking about the view you see when you hit the recent apps button. I like the stock ICS view too but that's a system thing, not just a skin.
Exactly that one man. It's just a shame that HTC went the way they did with the multitask.
Hopefully something is resolved this in future updates, and hopefully a possibility to flash this on a custom ROM. Now, I'm not too sure if that can ever be done because my exposure to rooting, ROM's etc isn't great by any means.
