Stormer1981
Ok - here is what happened and I can't seem to find any on line support.
I have a Galaxy S3 1535 Verizon model.
I successfully rooted using Odin and the pre-rooted tar files.
I also installed one of the CM10 nightlies and the AOPK Jelly Bean version as well as unlocked the boot loader. All good.
I decided I wanted to go back to ICS Rooted version. I had a problem with the MD5 checksum so I went to reflash the pre-rooted ICS version using Odin. That is where I got trouble.
I successfully flash the pre-rooted ICS version using Odin. However, I can't get the device to boot up. Odin tells me I "pass" and I get a "Samsung" flash up on the screen, then "Galaxy S3" then nothing. I have removed the battery and tried to re-insert. still nothing. I even went back and flashed the stock kernal. Same thing.
Anyone help?
Thanks.
Anyone help?
Thanks.
