Zoandroid
Android Expert
I have been running rooted stock Jelly Bean 4.1.1 for several months now, and have been making a nandroid and copying it and the files from both the Phone and Card folders as backups to my PC or notebook every week since I rooted the phone not long after getting it (when it first hit the market with Verizon).
Tonight, I am suddenly unable to get the stock USB cable, or any other USB cable, to make a connection, either to my same PC where I have made most of the file backups (Win7x64) or to my notebook, where I made a few of the backups (WinXP SP3).
Traditionally, when I would plug the S3 into one or the other computers, I would first hear the tone for connecting a charging cable, from the S3. Next I would hear the "USB connected" tone from the PC, oddly followed by the "USB DIS-connected" tone from the PC. But I was still able to copy files back and forth.
Tonight all I hear is the charging cable connecting tone. No USB action, and it never appears on the screen of the computer, or in Windows Explorer.
I did make this week's nandroid ( I use TWRP) without incident, but just can't copy files to the PC. So I tried restoring a nandroid made on July 27th. That works fine on the S3, but I STILL can't get a USB cable connection to a computer.
The only thing USB wise I have done differently was to buy a couple of right-angle (actually, they are "left angle" ) micro USB cables on Amazon, so I can hold the phone and use it while charging, without having the cable sticking straight out the bottom toward me. Could those cables possibly have done something to the USB circuitry inside the S3 and screwed it up? Aside from that, they seem to work fine for charging with a 1A charger.
I am stumped. Anyone have any ideas?
The only thing I can think of is if maybe the left angle cables have some kind of short between power or ground and one of the data lines, which perhaps the S3 tried to interpret in some way which made connecting as a media device impossible. Maybe I can try to make a breakout circuit and test to see if any of the cable's wires are shorted. I don't know that much about USB, but I would presume none of those lines should be connected to any other line within the cable, (when the cable is disconnected at both ends) should they?
