I have a CDMA Galaxy Nexus running AOKP Build 31 (Android 4.0.4).   I have a 4x2 Beautiful Widgets Superclock widget running on my home screen and it keeps freezing periodically.  I can't seem to identify a pattern.  Sometimes I'll turn my screen on and the clock will be fine.  Other times I turn the screen on, the clock will be frozen at an earlier time and will not update.
I tried removing and re-adding the widget to the home screen, but then I just get a placeholder that says "Loading..." The widget never loads though. I've also tried force closing Beautiful Widgets and that does not help. Neither does uninstalling and reinstalling it. I have to reboot my phone for the widget to work again once it's frozen.
I'm not sure if this is related to AOKP or not, but it's been doing this for the last few updates. When I went to build 31, I did a factory reset and wiped all data, but the problem persists. Yes, I did restore from Titanium Backup, and I have read that could be the problem. But I installed Beautiful Widgets and then re-installed it fresh without restoring data or the app, and it still does it.
So now I'm at a loss... I can't continue using the widget if I have to reboot my phone all the time to get it working.
Any suggestions?
Any suggestions?
