[Verizon] codename android from rom manager
*idroid*
if im downloading codename android from rom manager do i have to download the gapps too or does rom manager take care of it for me.
You need to download gapps as well.
Just a warning about rom manager I've seen plenty of botched downloads causing bootloops or force close fiestas when using rom manager to download and flash so if you have issues you might want to restore a backup and downloading via the browser
Feel free to try rom manager when it works it works well. Those few times it doesn't work cause issues ;) I personally like being able to check my md5 sums before flashing so I do everything manually and on the phone. If you know how to manually boot into recovery and flash/restore in recovery then you should be able to fix any issue that could happen :)
To add to what rexdog said the MD5 sum is unique to every file. Most rom devs will list the MD5 sum on their post about the rom, after you download the zip you check it and if it matches you know the file you downloaded is the exact copy of the file posted by the dev. If it differs at all then there is something different in the file (it is corrupted) and you should delete and download again.
The reason I don't like rom manager is because it doesn't check this or allow you to if you don't know where the dev's post is or if you use rom manager to flash the rom after the download.
