Help Verizon default ring tone question
DevinNJ
Member
In a stroke of genius I inadvertently deleted the Verizon default ringtone. Even in the list where you could just check on the word "default" it's gone. What did I do and how do I get it back? I downloaded a ringtone app and set a ringtone to "default" and when trying to change back to the stock default it was erased. Thanks in advance
Try Zedge. Use verizon as a search word and look at the ringtones. One of them might be the one you're looking for. (It's been so long since I had a Verizon phone that I can't remember the ringtone, and they've probably changed the default a few times since then.) It won't show as "default", it'll show as the name of the ringtone.
