Root [Verizon] Gmail will not auto-sync/push on rooted S3
dagactor
Hi All,
My rooted Verizon Galaxy S3 with Cleanrom Seven installed stopped automatically syncing my gmail. I can manually refresh my mail, but it does not sync automatically despite the sync being enabled. I've also wiped data, removed my google account, and even done a factory reset without restoring any google data...and although it occasionally works temporarily, it always stops working.
If a factory reset won't fix it, I don't know what to do anymore. Help?!?!?!
Thank you!!!
I had the same exact issue with CleanRom 7. Tried everything that you did . . . No help. I finally just re-installed the rom, & that fixed it. Not sure why that happened but that worked for me. Went back to CleanRom 6r2 later anyway & still running it. Even though its only 4.1.2, I like it waaaay better than 7 . . .
It's extremely stable. It also has a few features that I like . . . Call/message block,the long-press menu to kill foreground app, & I like the theme. Idk . . . I might go to 7 again, but for now I'm staying with 6r2 . . .
