Skeeter125
Did you try the workaround for the stock browser? Apparently you can use it at normal brightness.
I like chrome better anyway so for me I just stick with chrome.
got my new gs3 today, finally got to replace my droid charge that i wanted to smash every day. constantly getting stuck swithcing between 3g, 4g and mainly, no G. have both next to each other on desk. charge is -89db. , galaxy s3 is -109 db. really hope i didn't just make a downgrade. girlfriend got my charge and it appears that new sim card may have greatly increased the ability to stay on 4g. this is all based on the 1 hour since i switched them both over. have not made any calls, just used browser and setup apps, etc...
Thanks, saved me posting same thing.
Oh yea...almost forgot...Early Mon....I'm calling you out. I think you work for Qualcomm...lol Seriously tho...you be coming thru dropping some.....serious....knowledge.
Totally off subject but since this is about reception I want to share a amazing thing I bought today. I am upgrading to the S3 tomorrow but currently have a Razr. I live in a severe 4g fringe area and on ICS usually stand about -107db in my house. I bought the new Wilson Sleek 4G V signal booster make for verizon's LTE network and it is amazing. Ran the antennae out my window and stuck it in my rain gutter. Signal went to full bars, -75db. At the same time, my speediest.net results went from 3-4mb down and .5-1mb up all the way to 10-12 down and 3-5 up. Please don't flame me for putting off topic information I was just blown away with how much of a difference this thing can make.
for the millionth time, phones on gb read signal differently than ICS. ICS is about 20 dbm higher than what gb would read.
Why do people try to exclude the RAZR from the comparison? Someone else said the same thing when discussing battery life. I guess if you want the SIII and battery life and reception are important, then you have to remove Motorola from the mix.
A friend had a good saying "if you haven't seen the sun, you think the moon is bright".
I'm not coming here as a troll, or a Motorola fanboy, but to me, battery life and reception are more compelling to me than any of the features I've seen on the SIII.
Ken7, that is because it IS dim! I think either everbody else had dim phones before, or are blinded by new device pixie dust. The display is dim, even at 100%. My concern is battery life, since below 100% is even dimmer.
Very surprised my fellow Razr users did not mention this. Also, the Razr can be used outside fairly well, not so with much sun and the G3.
My Incredible is brighter, so the amoled tech here has even white, to the point of all shades of gray (hence it is dim).
Added:
Back on topic: Good to see the Gnex does not have a signal buddy in their review.
Np, you are on the right track since all you can really do (or anyone else) is test based on the phone you were using. A good check is any place you know you had issues with your previous phone, or was hit and miss for signal. Test the G3 in that area. If not working or even worse, you have the answer that matters most- your own results.
Without doubt, the Razr Maxx has very good signal. The Razr is probably the best, but for people that want a device similar in size to iPhone, but bigger display, the Incredible 4G is a good option and apparently very good signal as well. Also has the same S4 chip as the G3.
I get my G3 today and will bring it back to my office where on my Razr, 3G is weak and 4G is "fringy". If the G3 has weaker radios, I expect one or both to either not work or go "in and out". To me, this one test will be absolute, since if it does not work in my office, I have no point in having it.
My Razr is going either way (battery life), so would get the Maxx and wait to see what comes out later. Then again, the HD might be coming sooner than expected....
Added: In fact, to heck with bothering any further with the G3 if weak in my office. I will not bother installing my apps and will first test in my office. Will test streaming content, calls, speed test, open signal etc. If passes- COOL, if not, quickest return- ever for me.
Really, streaming video from a few sites that work fine on the Razr should be the most practical test and carry the most weight, so the other tests are not really needed now. Plenty of folks have done examples here and other forums and results are ALL OVER the place. All I would be doing is adding to the scatter chart![]()
np, that is weird, since most reports are the iPhone has weaker signal, but what matters is what you experience.
you2, I did turn off autobright and auto image contrast and set to 100%, but still dim even at 100%, compared to the Razr, Rezound, Gnex and even the Incredible. I think the answer is the display does not appear to have any whites. If you compare next to a device with whites, you see that the G3 is all shades of gray instead of white.
Your eyes adjust after a few minutes if just looking at the G3, but stands out when comparing to the other devices mentioned. I compared to all of them over the past few days and VZW store folks agree, or wanted to humor me.....
