I unlocked and rooted using Wug's tool kit, however I can't find any information on how to flash radios, etc.? Do you have to unzip the files first? Also, the link to the 4.04 radios is down.
I really appreciate your help.
Thanks...
How do you unzip using clockwork? I had unzip with winzip and tried flashing the img file within Wug's. Then it would not recognize the radios. I'll try again tomorrow. Thanks for the help.
If your downloading a .zip file of the radio in question, you would flash it like you do any other .zip in CWM. Flash it like you would a ROM, kernel, theme, etc...
What version of cwm are you running and where did you dnld the radio file from?
