Read thru this, if this is what you want to do...
http://forum.xda-developers.com/showthread.php?t=1867253
[url]http://108.166.171.38/goodata/aca9f9f3b54d94a22967b033cd0eeb29/50dc94d4/devs/invisiblek/i535/COMBINATION_I535VRALG1_I535VZWALG1_743127_REV09_user_low_ship.tar.zip[/url]
Not sure if this will help, but worth checking out for a solution to roaming:So I flashed the file, thought it was stock and ready to roll. The Internet was working via 4g but I was unable to send any texts or calls .. I did a factory wipe and now I'm getting this icon, which I believe is fo roaming.
https://www.dropbox.com/s/4f71k828r8k9u7m/Photo Dec 27, 8 32 48 PM.jpg
http://forum.xda-developers.com/showpost.php?p=35600769&postcount=2
Toonz i just went through that!! I was stuck in "Roaming" and couldn't make any calls or text. I even took the phone to VZW and they couldnt figure it out.
I tried everything i could think of! In the end, this is what worked:
http://forum.xda-developers.com/showthread.php?t=2066275
Nice find!! And bookmarked also!
I just tried running the root66.tar file and it failed in odin
I hope you get this resolved!
IT WORKED!!!!!!!!!!!!!!!!!!!!!!!!!!! Thank you for all your help and tips!!
@Mikestony I really appreciate your patience with me and helping me out.
Suh-weet! And no problem, I'm learning as I go also! If I ever get into a jam, I'll look ya up!
I'm happy you got it working...I really am![]()
http://db.tt/4lYuQrlu
It was on the top setting and I just switched this to 4g but it hasn't done anything
@rsarno any idea?
