Root [Verizon] Installing an .apk?
rimjay
Member
Good evening,
I wanted to install an .apk on my phone using a file manager such as Astro, but when i go to install it, it always says not downloaded. I tried using other file managers to install it to no avail. What am i doing wrong? Should i flash the .apk? Sounds silly but not sure what to do here.
Some system apps won't just install like a normal .apk. If that's the case you have to "push to /system/app". You have to be rooted to do this.
1. Open root file app, I use root browser, navigate to the apk you want to install.
2. Long press the apk and either copy or move apk
3. Navigate back to /system/app and paste the apk
4. Long press the apk and fix permissions
*the normal perms for system apps is
rw-rw-r--
5.reboot and enjoy
* if you are installing a new system app for example you want the 4.2.x camera on your 4.1.x ROM, you can and should rename the old one (androidappname).bak. by replacing apk with bak it will keep the file in case you want it back but it removes it as an active application.
