Hi,
Just got my S4 it came with the I545VRUFNG6 build.
Got it rooted and setup with safe strap no problem but alas it appears you can't install Cyanogenmod on this build?
"you must be on build I545VRUAMDK" from:
http://wiki.cyanogenmod.org/w/Install_CM_for_jflte
I've tried several versions of 11 (m10, m11) they boot but just keep force closing and you can never get in.
Is there any way to downgrade the bootloader to an earlier compatible version?
thanks in advance
thanks in advance
