Well I did make a guide, pretty much is a fairly straightforward method to upgrade to 4.4.2 rooted: http://androidforums.com/verizon-ga.../852829-guide-nonrooted-rooted-4-3-4-4-a.html
Digital Controller said:The Optional Stuff is Over
Step 24: From here we want to load our own ROM onto this sucka! So put your ROM in the storage of your device
Step 25: This is important, under the Wipe section click Advanced and make sure to wipe system/data/dalvik/cache
Step 26: Install the Rom you chose, here is a link to a few good ones!: Verizon Galaxy Note 3 Android Development - xda-developers
Step 27: Afterwards reboot into Download again
Step 28: This is where you open up Odin and it should look like this: LINK
Step 29: Once it validates the md5 we can press start at the bottom and once it is done it will auto reboot and you will have 4.4.2 on your device!
Step 30: Once you reboot, if you did the optional part, ignore this last step, otherwise, you need to install the 3.72 Safestrap version. Make sure to install Busybox from the Playstore as the new version of Safestrap requires it and not every ROM has it installed. First go into the older version of Safestrap and uninstall the recovery. Then install the newer version, make sure to allow unknown sources when it asks. Now you're done!
I usually don't make guides, but after all my terrible luck with this I felt it was necessary. Good luck and happy rooting!
No don't skip 1 through 23, there the part that is optional has a hide/show button in the middle of the thread.
Basically to get to 4.4.2 all you need to do is load the 4.4.2 ROM and the NC2 firmware / NC4 Modem and update safestrap.
Digital Controller said:If you are already rooted on 4.3 skip Steps 1 - 23
