[Verizon] Kernel sound control question
bcote311
When using a kernel that has sound control and turn the "Headphone Volume Boost" to 3 in TricksterMod and crank up the volume, it causes Google Music to crash. When I turn it to 1 or 0 everything plays just fine and it seems to happen only when the volume is turned up really high while plugged into my truck's aux port. This is not kernel or rom specific as it has happened on several different ones. My question is is there a kernel setting that controls power output or some other setting that may be causing the program to stop? Has this ever happened to anyone else?
