[Verizon] Lockscreen wallpaper
JE78
I'm running Liquidsmooth 1.25 ROM and i'm wondering if there is anyway to set picture I took with the phone as the lock screen photo without having to crop it half the size?
The only way I know to do that is to increase the canvas size of the photo on the desktop version of Photoshop. If there's an app that does that, I'd like to know about it.
Thanks. I'll give that a try with Photoshop. I would think there would be a fix or something for this. I'll keep looking.
I am wondering how to remove the lock screen wallpaper and just go back to it showing my other wallpaper which is a live wallpaper. I can't figure it out at all. It says remove the wallpaper in the above menu but there is no menu above.
If only it was that simple. In the liquid setting it won't let me choose any other wallpaper except a photo from my gallery. So I can't choose live wallpaper for the lock screen.
Oh sorry. Just goto the normal display menu/wallpaper section and choose the live wallpaper.
under liquid controls/lockscreen wallpaper tap on the 3 menu bubbles in the upper right and choose to reset wallpaper, I assume this will do it.
