Root [Verizon] MMS problem
dkl1
Android Expert
Curious if anyone else is having problems sending pics via text messages? I use Handcent and have never had a problem but for some reason it will NOT send! Help me Rhonda! :D
Did this problem just happen today? Is it a certain pic that wont send, or any pic? Is it not sending to a certain contact or all contacts?
What rom are you on? What are you smokin? lol Is your signal good? Can you receive pics? Like all my questions?:)
MAN! What are you a JOURNALIST?! :p. Them there are sooooommme questions :D
There is no pic that will send. Dont know about which contacts they will or won't send to...I just know when I have tried to sending an attached pic to a couple contacts they simply won't gooooo :confused:
I'm running CleanRom at present...
Are you enjoying the new device?
My finger slipped, hit the submit button. Then I went to edit it and got a phone call....!!!
haha, no problem!
I don't use Handcent myself, but have you recently made some settings changes in it?
Did this just happen today?
Can you receive mms pics?
Perhaps try the default text messaging app and see if you can send mms.
And I am loving my new device...tweaking it here and there, nothing major yet.:)
It's been happening at least since last Sunday. I don't recall making any changes to my settings....hmmmmm? Can't 'member your other 14 questions! Lol :p
do you disable the stock messaging app? Most third party mms/sms apps require the stock messaging app running in the background. The current sms/mms app I use is Verizon Messages, which is the only 3rd party mms/sms app to run fine with a disable stock messaging app.
While I never liked handcent, I have had used it in the past and mms worked fine for me.
