[Verizon] my first flashing problem...worried
sessman
ok so im in trouble, I flashed wiped and flashed liquid smooth jelly bean beta 2 and I got "the launcher has stopped working unexpectedly" over and over and over to the point I had to battery pull to make it stop but right when i restarted it would do it again. Im using Team Win recovery so I went into that and tried to wipe and reflash but the problem is I wiped my SD card and the rom while wiping and now I have nothing on my sd card. i cant restart because it says no OS installed. I tried mounting the phone to the computer through recovery but it doesnt show up on my computer so i can add another rom to the root of the sd card. what do i do?
Don't panic! Someone here knows how to fix this, just not me. The solution will be to get your phone recognized on your PC, then push a ROM zip to the phone's SD card and flash it. I don't have the details on how to set up Android SDK handy, but I will look for them and report back if I find them.
Radios- no problem.
BL- wouldn't worry about it since you're probably going back to JB again, right? :D
If you do back to stock, it'll be the way it was when you bought it. Since you wiped the sdcard already, nothing to lose.
Radios- no problem.
im gonna run stock for awhile, every rom i flash works great for a week max then gives me head aches, kinda over it. do i have to do OEM lock to accept the OTA updates?
