dkl1
Android Expert
There simply doesn't seem to be much info on nandroids! I was very comfortable making them when I was an EVO 4G user and I knew where they were stored and how to restore from one and so on.
My SGS3 device is rooted by way of the flash method, placed TWRP 2.2 as my recovery, plus I unlocked the bootloader. I'm sitting here thinking "...if I were to want to go to do a restore of a nandroid, I'm not certain I'd know where to look! I did discover a TWRP folder on the /mnt/extsdcard and within that is a BACKUPS folder which contains a folder "d319cbf3" then within that contains a folder "1970-01-05--22-53-53" (note: when I long-press on this folder and go to 'Properties' it states that it was modified "1979-12-31"!!!
Once I open that folder up I discover 6 files - two 'boot' files, two 'data' files and 2 'system' files. Are these my nandroid files that serve to restore the device to the earlier ROM?
Now just to clarify, that nandroid is one that I made after I rooted and switched recovery and unlocked the bootloader. I DID NOT flash a different ROM but am still using the stock ROM. I am not wanting to restore it because it is basically what I'm currently running (however, I have considered making a new nand simply because I have changed up some stuff since that one was created!). I think I have some grip on the subject but still feel that since I'm on a brand new device that there's enough difference in the way this device operates as compared to my previous EVO 4G that I would like to read more on the subject...
sorry for the rambling but just trying to be as clear as possible!
Thanks for your input.
