[Verizon] Need help flashing JB 4.2.2 using WugFresh.
WugFresh will download what you need in order to flash. I'm not sure if you can tell it to use a file downloaded outside the app. If not, it'll download and help you flash the stock image anyway. Best of luck!
Yeah there is a part that says boot/flash image, but inside there are thee files.
bootloader-toro-primelc03
radio-cdma-toro-i515.fk01
radio-toro-i515.fk02
Which one do I flash or do I flash all of them? And where do I flash it to? I have these options.
Boot
Bootloader
Raido/Baseband
Recovery
System
Userdata
Boot
Bootloader
Radio/Baseband
Recovery
System
Userdata
The first list of stuff is the bootloader and radios.
However, you are going to want to flash all of the second list.
Looks like I screwd up and installed the bootloader-toro-primelc03 to the System instead of the bootloader, now I am getting a error saying USB device not reconsigned.
It looks to me like you're trying to restore from a factory image. In that case, make sure fastboot is in your path and run the appropriate script in the folder you extracted the files to
Ok I just did the OTA update, but how to I root now cause JB 4.2.2 is not on the list.
