Help Verizon Note Edge missing features
tinyt1553
Hi everyone,
2 things really annoying me about the Verizon version of the Samsung Galaxy Note Edge (SM-N915V);
First: Where is the Samsung Galaxy Apps app? (previously had this phone on AT&T (SM-N915A, the app was there), switched to Verizon model about a week ago and still can't find Galaxy Apps or Samsung Apps
Second: Once of my favorite features since the KitKat was released, is the ability to view the phone settings in Tab View. I hate list view. My Note 2 on Verizon had tab view, and my Note Edge on AT&T had it, but Verizon doesn't seem to incorporate it. (once in settings, hit menu button (top right), select tab view (not there on Verizon version)).
ANY HELP OR POINTERS ON EITHER OF MY COMPLAINTS (OTHER THAN SWITCHING PHONES/CARREIRS) IS APPRECIATED.
If you go into your apps and hit the 3-dot menu button in the upper right corner, there is a Galaxy Essentials selection. It can get you to the Galaxy Apps store. Hope this helps.
Yes, you are correct thank you. I wasn't seeing it there because I'm using NovaLauncher instead of the default touchwiz. I will contact Nova and ask them to incorporate. Any ideas on how to view settings in tab style instead of list style?
They placed it in a widget on the last home screen next to the S Health one. It sucks to not have an icon to use in the Edge portion as I have started using it more than the unreliable Play store
