Root [Verizon] Nova launcher and Lockscreen Wallpaper
MsL
I have a rooted Gallery S3 running CleanRom and Nova Launcher. I am trying to set up my lock screen and would like a different wallpaper but I can't for the life of me figure out how to change it.
My son has the same phone unrooted and all he has to do is long press the homepage and under wallpaper he has the option to change the lockscreen or the homescreen.
I can make every other change in my lockscreen but the wallpaper.
Any suggestions?
Thank you,
I knew someone would have the answer. One more question, it appears that I can't put live wallpaper on the lock screen is that correct?
hmmm...never tried it or looked into it. :(
Sorry only one answer per thread.
Just kidding :D Sorry, but I don't know about the live wallpaper thing.
I can check around for ya, or try it......it won't allow you to do that?
No the options are only gallery or wallpaper and when you click wallpaper it brings up the basic wallpaper. I believe it I was to choose lockscreen and homescreen I could use the live but not just the lockscreen.
I can confirm that Live Wallpaper should work on the most recent version of CleanROM with Nova. That being said, I use Nova Prime, but it should work either way, I just had my phone set up like that yesterday. Not sure why its not giving you the choice, I would reset and re flash if you can get it to work.
Thank you. I am using Prime as well but if I want a different live wallpaper on the lock screen I don't have that option.
Ohhh. I'm sorry, you mean a live wallpaper on the lock screen, and a different wallpaper/live wallpaper on the home screen?
I don't know if this is possible because I have never tried.
Sorry for misunderstanding. XD
