Root [Verizon] Odin kernel swap help please.
ncdude
Hi all,
I was trying the kernel swap on my s5 but I still only get towelroot to hang after hitting the make it rain button. Has anyone been able to get this method to work? If you have please share with me how you did it. I followed the steps I found online.
I appreciate the help.
What steps did you follow? What release was your OS before attempting the process? What OS release are you at now?
1. Take the NCG to NE9 OTA Update or flash the G900VVRU1ANE9 Retail tar in PDA slot in Odin(AP in Odin v3.09+).
2. Place your phone into "Download Mode" (press and hold the Home, Volume Down, and Power keys until the phone powers on and displays warning screen, then press Volume Up key).
3. Flash the G900V_NCG_Stock_Kernel using Odin's PDA slot(AP in Odin v3.09+).
4. Root using Towelroot.
5. Power off then boot into "Download Mode" again.
6. Flash the G900V_NE9_Stock_Kernel also in Odin's PDA slot(AP in Odin v3.09+). Done!
Notes: After flashing the NCG kernel your phone may run a little wonky and towelroot may not root on the first try. If that happens reboot and try towelroot once again. Once rooted and after flashing the NE9 kernel your phone will run like a champ again!
Important!: Do not skip any steps or you may experience issues with your device after following this process.
Android version 4.4.4
Model SM-G900V
Kernel 3.4.0
As far as I can tell nothing changed.
Tried that way as well and same results, Towelroot hangs and never reboots. Any other ideas?
I do appreciate the support, thank you
Still need you to answer the questions in my first post above. And was the phone already rooted before starting this process? If so, you may have to do a factory reset to get it back to stock before doing the other steps.
If it's never been rooted, this should be a piece of cake.
4.4.4 this whole time, it never changed. I know this should be easy but damn if towelroot doesn't just sit there. I have set the phone down for 15 minutes and come back to check that towel root is still sitting there. I have two versions of towelroot, ver 3 and the first ver. Are there any others?
I used version 3.
My only suggestion at this point is a factory reset and then running the process I linked to again. Take the OTA to NI2 first before doing the rooting process. You could use Helium to backup your system, and do a restore once rooted and on NI2.
I decided to head over here to see what all is going on because I haven't been here in a while. We have most of the big breakthroughs over at XDA. I also needed a break from trying to mod SafeStrap to support external sd ROM slots Lol. But anyway, have you had any luck with your phone? A lot of people have been having the same problem as you and we never mind stepping in and helping, to see if something simple might have just been missed. I'm not sure what exact steps you've tried, but there are only three that really matter, when it comes to the actual phone side of it.
1. Boot to Download Mode and flash NCG firmware only with Odin
2. Boot normally and run Towelroot (use Ver 3)
3. Boot back to Download Mode when rooting is complete, and flash NI2 firmware only with Odin. Then reboot=Profit!
This is assuming you have the correct Samsung drivers installed and you have Odin and all that good stuff. The version of Android you're running isn't a factor at all. Flashing the NCG firmware isn't going to change the version of Android you're on, because it's just the kernel, not the full OS. It kind of sounds like the firmware isn't flashing correctly in Odin though. Did you make sure to enable USB Debugging before using Odin in Download Mode? If you have any more problems and can't figure it out, you can get with me here or through PM. I don't mind walking you through the process so we can figure out what's wrong.
