[Verizon] Recovery Not Backing Up
andoird213
Android Expert
Hi all,
Well I just decided to try out TWRP (2.1.2). I tried to make a backup and it gets stuck on data and can't successfully complete the backup. I did leave it there for a good deal of time, over a half an hour, and it couldn't complete it. I had to resort to a battery pull. Now this same exact issue occurs on the official CWMR Touch build from ROM Manager. The only recovery that I can seem to successfully make a backup in is a beta version of CWMR Touch (beta 5). Does anyone have any ideas? This is quite frustrating and I don't enjoy being on such an outdated build and one with, in comparison to TWRP, less features. I'd really appreciate any ideas.
Thanks!
Hi all,
Thanks!
Could you try something? Make a backup of your sdcard and put it on your PC. Now format your sdcard from your PC (use FAT32 quick format)(you on Windows 7?). SO nothing is on it. Now install the latest cwm and try to make a backup. See if it works.
Not on Windows :/
