Root [Verizon] [ROM] VZW LG G2 KitKat 24a ROM
MicroMod777
After 3 bricks and lots of testing, here's my VZW G2 KitKat 24a ROM's, stock and debloated.
Special thanks to xdabbeb method and kernel and JackpotCalvin KK hack for without them, this would not be possible. :svetius:
Must be taken the VZW ota 11a or higher and be on custom recovery.
Cooks or Devs:
Anybody can use part of all of this rom as a base as I don't own this rom. Just posting a credit is sufficient enough for me. My loss of 3 bricks is your gain! :)
Warning MD5 must match or risk brick due to kk baseband being flashed.
ROM's:
FULL WIPE NEEDED
Steps 1: Flash ROM
Step 2: Flash kk baseband. Must be on 11a, 12b. If ur on 24a u don't need baseband.
Downloads:
VZW KitKat 24a Stock Rooted
MD5: 08da9192677f50485725c08fc13ad537
https://mega.co.nz/#!QFdnxBbA!S-Ij_ncMrvfNm_HK2h9dP60o14g9UVlp4ReN6LT_ZEw
VZW Kitkat 24a deblotated, rooted ROM download:
MD5: 1d962bec79d1bf7668a1cd7b7f5eeb95
ROM V1.2
https://mega.co.nz/#!ZRVD1ZIb!0XRk74BpYcWxM7VA5jTGL7fnElXDl8fo6m0Npf_N8os
KK Baseband look for zip vs980_1xx_to_24a.zip thanks to okibi.
https://docs.google.com/document/d/1xsU9W656TA-Lw1LAlL7hqROf2QjiOI2puyDU-DDP41Q/mobilebasic?pli=1
Use MD5 checker apps from play store or...
MD5 File checker tool download for windows:
https://mega.co.nz/#!oI9lnaKK!awKao0BixC0BALdA6w4fwQnwP1VaJTX0AXyxorkh0QA
and install this rom and did the steps for hiddenmenu but does not work as it should I have to take her time and do not always go as I can fix it ???
