Root [Verizon] Root Issue
desmofan
I bought my S3 used, and it was already rooted. It seems to periodically be running VERY slowly, lots of lag, and some screen taps taking literally 30 seconds to register. I'd like to change ROMs to see if that is the issue (currently running "The Executioner", as it was on the phone when I bought it). The problem is that I don't think the phone is rooted correctly. Root Checker Pro says "Root Access is not properly configured or was not granted". And, as such, Titanium Backup does not work. I'd hate to have to recreate all my folders, and lose all my app data, seeing as I can't backup.
Any ideas?
[FONT=Verdana, serif]You may need to wipe the cache partition, do the following:[/FONT]
[FONT=Verdana, serif]1. Turn off the device.[/FONT]
[FONT=Verdana, serif]2. Press and hold the Volume Up key, Home key, and Power key at the same time.[/FONT]
[FONT=Verdana, serif]3. [/FONT][FONT=Verdana, serif]When the phone vibrates, let go of the Power key but continue to press and hold the Volume Up key and the Home key.[/FONT]
[FONT=Verdana, serif]4. Press the Volume Down key to move to and highlight wipe cache partition.[/FONT]
[FONT=Verdana, serif]5. Press the Power key to select and wipe the cache partition.[/FONT]
[FONT=Verdana, serif]6. After the wipe is finished, go back up till reboot system now is highlighted and press the Power key to restart the phone.[/FONT]
