Verizon I assume? There are different methods to root for different carriers.Can you do all the same things when it comes to rooting and putting roms on the LTE version as on the regular S3?
Yes i meant the bootloader XD thanks a lot. and i do know what i am doing. I have the CM 10 on my Lucid. can you get that in the S3 as well? also, just to be 100% certain if i root and put a mod on it can i undo everything just like i did on the Lucid?
Not sure I follow you...it should work right out of the box.Question again XD. Is there any MOD's out there that allows the Samsung S-Beam feature?
Well, I can't speak for other roms (I don't flash many roms...shhhh, don't tell anyoneSo the S Beam works on all mods/roms?
The keyboard is nice...I use the Samsung keyboard that came with it. I can also choose Swype if I wanted. Been getting used to the swype type keyboards. Besides, there's a buttload of other keyboards available in the PlayStore if you do not like the default one. Oh, check out A.I. Type Keyboard in the Play Store....it's nice tooCool you have Clean Rom. How is the keyboard? The Stock one is slow and clunky as hell. Can you move the APP button in the dock? Are you able to overclock it? and if not do you know of any Kernels that work with it so i can OC it?
So i have Clean Rom on it with the LeanK installed as well. Works like a dream now. But im running into a problem where no computer is recognizing the phone as a mass storage device. I cant get any files on or off the phone or SD card. I have also tried using the SGS3 Easy UMS 1.2beta2 and the 1.8 but nothing seems to be working. Any thoughts?
Ok. I had uninstalled the drivers and re-installed them and all the sudden the phone is now popping up as a freaking CD drive???????
