Root [Verizon] Running Official CM10 but need help with NFL Mobile..
Does anyone know if there's a fix for running the NFL Mobile App cuz right now all I get when I try to open it is that its for Verizon Customers only...I was running it OK when using the Synergy ROM but I can't get it to work in CM10...any ideas?
i dont believe the NFL Mobile app has EVER worked on the AOSP ROMs...AFAIK there is no fix and i would never expect one...
it works on Synergy because the underlying framework is VZW issued TouchWiz
Do you know of any other stable roms with a good custom OC Kernel that NFL Mobile would work on?
Thanks
Works on Synergy, on Clean Rom if you go that route do not install the NFL App, or any of the Verizon apps during the ROM install. Then search and install the verizon SSO and the NFL app, and maybe my verizon and it will work. That is how I got it to work.
